We having been slowly but surely trying to implement indoors for our county facilities. This will include several hundred facilities. I just noticed that by default it seems to always show the Ground (vert order 0) features in the map - both Pro and our published AGO indoor maps.
My questions:
- How do I override or adjust this default filter setting?
- Why do the units/details also display by default (I would expect only the "Level" feature class to show)
- When applying a filter for a different building, the default filter for the ground floor still persists, which does not make sense. Is this expected behavior for the default setting
After a lot of searching I did find this in the documentation. There has been a lot of hunting for straight forward Indoors documentation....: Visualize floor-aware data using the floor filter—ArcGIS Pro | Documentation assuming that if you don't want the default filter included to turn off the floor filter before publishing?
Lastly, like I mentioned before - this indoors model will include a lot of facilities all with their own set up of floors which has made the level layer a bit complicated. Is there good documentation or examples for using indoors at this scale? I feel most documentation is generally focused on one office building rather than a large geographic area (county).
Thanks for any help/suggestions/insight!
Mary
