Using the .NET SDK, I have found GeodatabaseHelperFunctions.BuildSchema() changes invalid field names however there no function to know which field names have been changed.
When I import a table from within ArcGIS Pro using Display XY Data, I can see that it is changing "Group" to "Group_". This is using the default file geodatabase that is created in the project.
So, clearly there are two elements which contribute towards a valid Field Name, 1. valid characters and 2. valid names, or rather NOT invalid names.
I've found documentation which lists valid/invalid characters but I can't really find the same for words beyond a generic, some words may not be valid.
This issue is causing me a problem when trying to map a DataTable column to the Geodatabase column. i.e. getting an invalid index exception.
For python, there's a ArcPy function ValidateFieldName_management however, .NET SDK does not have an equivilent.
I'm happy to write my own code however, I obviously don't know which names wouild be invalid.
Is there somewhere I can obtain the list of invalid Field Names?
