Greetings,
I have ArcGIS Monitor tracking response times for my services. I consistently see response times for most services in the 0.8 second range. Several times a day I see response time jump to nearly 4 seconds on my Image Services. This is intermittent and is normally under 1 second.
I have reviewed all the logs in Portal, Server, Server statistics, Monitor and System Event Viewer for the specific time frames in question. I can find the requests that are made for the problematic services in each respective logging environment.
What I do not have is the "trace" information to discover exactly what is causing the long response times. Once the request for the Image Service is made it has trail from the requesting service, to Portal, Server, Tile Cache, Database... etc... I am not exactly sure...
Can someone direct me to a solution to discover the delay? I am accustomed to the SDE intercept process as an example to discover slow, bad, queries, etc....
After all the traditional configuration tweaks are accomplished to speed things up, I want to discover what goes "wrong" at different times of the day for specific services.
What is the prescribed method to find delays in response times? Something like "tracert" or "sdeintercept" anything like this available? Am I missing something obvious?
@EsriEvan thought I would hit you up since you chimed in on another performance issue I posed regarding this sort of question.. Solved: What is measured for the "Average Response Time" ? - Esri Community
Thank you in advance.
@SGTomlins
