Server Error in Application "DEFAULT WEB SITE/ARCGIS" Internet Information Services 7.0 Error Summary: HTTP Error 500.0 - Internal Server Error Calling LoadLibraryEx on ISAPI filter "C:\IBM\WebSphere\Plugins\bin\IIS_webserver1\iisWASPlugin_http.dll" failed Detailed Error Information: Module: IIS Web Core Notification: Unknown Handler: WebAdaptorHandler Error Code: 0x800700c1 Requested URL: http://localhost:80/arcgis/webadaptor Physical Path: C:\inetpub\wwwroot\arcgis\webadaptor Logon Method: Not yet determined Logon User: Not yet determined Most likely causes: �?�IIS received the request; however, an internal error occurred during the processing of the request. The root cause of this error depends on which module handles the request and what was happening in the worker process when this error occurred. �?�IIS was not able to access the web.config file for the Web site or application. This can occur if the NTFS permissions are set incorrectly. �?�IIS was not able to process configuration for the Web site or application. �?�The authenticated user does not have permission to use this DLL. �?�The request is mapped to a managed handler but the .NET Extensibility Feature is not installed. Things you can try: �?�Ensure that the NTFS permissions for the web.config file are correct and allow access to the Web server's machine account. �?�Check the event logs to see if any additional information was logged. �?�Verify the permissions for the DLL. �?�Install the .NET Extensibility feature if the request is mapped to a managed handler.
Thanks for the post! Solved my issue...
