I am trying to construct a start/stop editing button that will also switch to the appropriate version for the user that is logged in to the database. I am having an issue changing versions from SDE.Default to a child version of a child (if that makes sense). We have versions that are children of default and then I build editable private child versions off of those. Am I missing a step somewhere? The Contents pane does not refresh to indicate that version change occurs. It doesn't error out - it just doesn't do anything.Using the Change Version tool in Pro works.
using Version = ArcGIS.Core.Data.Version;
internal class StartStopEditing : Button
public Geodatabase transactionalGDB = null;
protected async override void OnClick()
if (!Project.Current.IsEditingEnabled)
//Change or Create Version based on user name
//Get the BOZAS layer from the map
FeatureLayer pFL = MapView.Active.Map.GetLayersAsFlattenedList().FirstOrDefault(x => x.Name == "BOZAS") as FeatureLayer;
if (pFL != null)
//Get the BOZAS layer geodatabase and from that the user name
Datastore ds = await Helper.GetDatastoreFromFeatureLayer(pFL) as Datastore;
await QueuedTask.Run(() =>
if (ds.GetConnectionString().ToUpper().Contains(Helper.desktopConfig.Transactional.ToUpper()))
transactionalGDB = ds as Geodatabase;
Helper.g_User = (ds.GetConnector() as DatabaseConnectionProperties).User;
string versionName = "BOZAS_" + Helper.g_User.ToUpper();
if (transactionalGDB != null)
using (VersionManager versionManager = transactionalGDB.GetVersionManager())
Version fromVersion = versionManager.GetCurrentVersion();
//Check if Version Exists
IReadOnlyList<string> versionList = versionManager.GetVersionNames();
if (versionList.Contains(Helper.g_User.ToUpper() + "." + versionName))
//If So, Change to It
Version userVersion = versionManager.GetVersion(Helper.g_User.ToUpper() + "." + versionName);
MapView.Active.Map.ChangeVersion(fromVersion, userVersion);
//If not, create it and then switch to it
else
VersionDescription versionDescription = new VersionDescription() { AccessType = VersionAccessType.Private, Name = versionName, Description = "BOZAS Edit Version: " + Helper.g_User };
Version parent = versionManager.GetVersion("JEFLIB.JEFLIB_E"); //This is set to Public
Version newVersion = versionManager.CreateVersion(versionDescription, parent);
MapView.Active.Map.ChangeVersion(fromVersion, newVersion);
//Enable Editing
await Project.Current.SetIsEditingEnabledAsync(true);
return;
else
MessageBox.Show("No BOZAS layer found. Please insure that the BOZAS.aprx file is open in ArcGISPro and that the BOZAS layer has not been removed or renamed.", "No BOZAS Layer", System.Windows.MessageBoxButton.OK, System.Windows.MessageBoxImage.Exclamation);
return;
if (Project.Current.IsEditingEnabled)
//Deal with saving edits before setting SetIsEditingEnabledAsync to false
Project.Current.SetIsEditingEnabledAsync(false);
