I found a bug in the library,
by using enclayers for s57, when using identifyLayers for searching objects represented in the map a crash occurs.
By trying to understand if I was making something wrong, I found that the bug happens if an identifyLayers is running and the user move the map.
I was able to reproduce this using arcgis V100.15 and V200.3.
The same happens by using identifyLayers (deprecated) or identifyLayersAsync (new method).
I tried to find a workaround, but there is no way to solve this. I think it should be corrected in the library:
- I tryed to intercept the begin of maps movement operation (navigatingChanged event) to protect the identifyLayers operation. but No luck
- I removed all my code, just to be sure that was not a problem of mine.
Does someone have idea to solve it?
In attachment there is a simple software (made with QtCreator) that issues identifyLayers requests and moves the cartography position, the crash timing is randomic but it always happens within a minute after start.
N.B.: I tried to contact directly the customer-care, but they answered:
Unfortunately, the information you provided does not appear to be a report of a bug
I think they answered without trying the attached source code.
