I am trying to create a workflow in the ArcGIS Pro Tasks/Task Designer (running Pro v.3.2.1) panes. This workflow is intended to outline our internal workflow of creating and updating a street grid index map that we produce. We have created a custom script tool that is an integral step to the workflow for this map (see attached screenshot). I am on the step that would run this script tool, but I cannot find a way to add a custom script tool to a task in ArcGIS Pro. I presume that if you could add script tools to a task, that it would be under the "Actions" tab in the Task Designer pane. Is adding custom script tools to an ArcGIS Pro tasks workflow possible? Could this be a possible recommendation for ArcGIS Pro Ideas if so?
