Hello, so I am very new to using python more and more with GIS. However, I have ran across a problem that I cannot seem to figure out. We are trying an evaluation copy of ArcGIS GeoEvent Server. One cool idea that we are going for is basically reading an excel sheet as it is updated. I am messing around with some feature class that we have not pretaining to actual real time data that changes, and wanted to give it a shot to see if i could export it to excel.
<SPAN class="keyword token">import</SPAN> pyodbc
<SPAN class="keyword token">import</SPAN> csv
connection <SPAN class="operator token">=</SPAN> pyodbc<SPAN class="punctuation token">.</SPAN>connect<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Driver={SQL Server Native Client 11.0};"</SPAN>
<SPAN class="string token">"Server=Server;"</SPAN>
<SPAN class="string token">"Database=Database;"</SPAN>
<SPAN class="string token">"uid=username;pwd=password"</SPAN><SPAN class="punctuation token">)</SPAN>
cursor <SPAN class="operator token">=</SPAN> connection<SPAN class="punctuation token">.</SPAN>cursor<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
cursor<SPAN class="punctuation token">.</SPAN>execute<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"select Name, SITE_NAME,ADDRESS from Power_plants"</SPAN><SPAN class="punctuation token">)</SPAN>
data<SPAN class="operator token">=</SPAN>cursor<SPAN class="punctuation token">.</SPAN>fetchall<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'dataTester.csv'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'w'</SPAN><SPAN class="punctuation token">,</SPAN> newline<SPAN class="operator token">=</SPAN><SPAN class="string token">''</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> fp<SPAN class="punctuation token">:</SPAN>
a<SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>writer<SPAN class="punctuation token">(</SPAN>fp<SPAN class="punctuation token">,</SPAN> delimiter<SPAN class="operator token">=</SPAN><SPAN class="string token">','</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> line <SPAN class="keyword token">in</SPAN> data<SPAN class="punctuation token">:</SPAN>
a<SPAN class="punctuation token">.</SPAN>writerows<SPAN class="punctuation token">(</SPAN>line<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> data<SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
cursor<SPAN class="punctuation token">.</SPAN>close<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
connection<SPAN class="punctuation token">.</SPAN>close<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Currently this is what I have. I was able to connect to the database fine, however I changed all of that for security. But then I have it print to console, and that also works fine. However when it goes into excel, it somehow makes every letter in the words a new column. See attached screen shot.
What do I need to do in my code to fix this??
