This script is far from perfect, but I'm getting a very strange error message and I was hopeful someone could help me solve the issue. Thank You for your time:
ERROR 000301: The workspace is of the wrong type
import arcpy
import sys
import os
import time, datetime
#import pyodbc
import traceback
# \\\\Constant Vars\\\\
# Database Connection
editDB ="Database Connections/EdnaRoad_Admin.sde"
# Current Day
Day = time.strftime("%m-%d-%Y", time.localtime())
# Current Time
Time = time.strftime("%I:%M:%S %p", time.localtime())
# \\\\pyodbc.connect vars\\\\
#sqlsvrname = 'gisavglis'
#sqldbname = 'Arden'
loggingTableName = "dbo.PYTHON_SCRIPT_LOGGING"
# Set workspace
workspace = editDB
# Set the workspace environment
arcpy.env.workspace = workspace
def log_messages(scriptName,Status, ErrorCode):
runDate = datetime.datetime.fromtimestamp(time.time()).strftime('%Y-%m-%d %H:%M:%S')
egdb_conn = arcpy.ArcSDESQLExecute(workspace)
sql = "INSERT INTO {4} (ScriptName,RunDate,Status,ErrorCode) VALUES ('{0}','{1}','{2}','{3}')".format(scriptName, runDate, Status, ErrorCode, loggingTableName)
try:
egdb_conn.startTransaction()
print("Attempt to execute SQL Statement: {0}".format(sql))
egdb_return = egdb_conn.execute(sql)
egdb_conn.commitTransaction()
except Exception as err:
print(err)
egdb_return = False
try:
# Start Time
print 'Process Started at ' + str(Day) + " " + str(Time)
# block new connections to the working and prod database.
print "Blocking Connections..."
arcpy.AcceptConnections(editDB, False)
# disconnect all users from the working and prod database.
print "Disconnecting Users..."
arcpy.DisconnectUser(editDB, "ALL")
# Get a list of all versions besides QAQC and DEFAULT to pass into the ReconcileVersions tool.
ver1List = [ver1.name for ver1 in arcpy.da.ListVersions(editDB) if ver1.name != 'DBO.Quality Control' and ver1.name != 'dbo.DEFAULT']
# Execute the ReconcileVersions tool with QAQC Target Version then delete all versions besides QAQC
print "Reconcile/post versions to Quality Control...."
arcpy.ReconcileVersions_management(editDB, "ALL_VERSIONS", "DBO.Quality Control", ver1List, "LOCK_ACQUIRED", "NO_ABORT", "BY_OBJECT", "FAVOR_EDIT_VERSION", "POST", "")
# Extract QAQC version from the list of versions to pass to ReconcileVersions tool.
ver2List = [ver2.name for ver2 in arcpy.da.ListVersions(editDB) if ver2.name == 'DBO.Quality Control']
# Execute the ReconcileVersions tool with DEFAULT Target Version and delete QAQC version
print "Reconcile/post Quality Control to DEFAULT..."
arcpy.ReconcileVersions_management(editDB, "ALL_VERSIONS", "dbo.DEFAULT", ver2List, "LOCK_ACQUIRED", "NO_ABORT", "BY_OBJECT", "FAVOR_EDIT_VERSION", "POST", "")
print("==============================")
print ("Unregister Tables Started")
# **** wildcards for tables I don't want to include ****
for tbs in [tb for tb in arcpy.ListTables() if '_log' not in tb and 'GenerateId' not in tb and 'PYTHON_SCRIPT' not in tb]:
print tbs
arcpy.UnregisterAsVersioned_management(tbs,"NO_KEEP_EDIT","COMPRESS_DEFAULT")
# If you want to include all tables in the database use this instead:
# for tbs in arcpy.ListTables():
# print tbs
# arcpy.UnregisterAsVersioned_management(tbs,"NO_KEEP_EDIT","COMPRESS_DEFAULT")
print ("Unregister Feature Classes is started")
datasets = arcpy.ListDatasets("*", "Feature")
for dataset in datasets:
fcList = arcpy.ListFeatureClasses("*","",dataset)
for fc in fcList:
print fc
arcpy.UnregisterAsVersioned_management(fc,"NO_KEEP_EDIT","COMPRESS_DEFAULT")
# Run the compress tool.
print "Compressing database..."
arcpy.Compress_management(editDB)
# \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ script initiation, Rec/Post process error handling \\\\\\\\\\\\\\\\\\\\\\\\\\\\\
except:
print 'An error occured'
failMsg = '\nSCRIPT FAILURE IN SCRIPT INITIATION OR RECONCILE-POST PROCESS, \n'
failMsg += 'Most recent GP messages below.\n'
failMsg += arcpy.GetMessages() +'\n'
failMsg += '\nTraceback messages below.\n'
failMsg += traceback.format_exc().splitlines()[-1]
print failMsg
#write error log info
print 'Logging error to database....'
# THIS SECTION FOR LOGGING ERRORS TO A DB TABLE
log_messages('ReconcilePost_AssetIDs_QAQC','Failure', failMsg)
sys.exit()
# ////////////////////////////////////// REGISTER AS VERSIONED AND RE-CREATE VERSIONS /////////////////////////////////
try:
print ("register tables is started")
# **** wildcards for tables I don't want to version ****
print tbs
arcpy.RegisterAsVersioned_management(tbs, "NO_EDITS_TO_BASE")
# If you want to include all tables in the database use this:
# print tbs
# arcpy.RegisterAsVersioned_management(tbs, "NO_EDITS_TO_BASE")
print ("register Feature Class is started")
for fc in fcList:
print fc
arcpy.RegisterAsVersioned_management(fc, "NO_EDITS_TO_BASE")
# create versions
#print "Creating Versions..."
#arcpy.CreateVersion_management(editDB, 'dbo.DEFAULT', 'QAQC', 'PRIVATE')
#arcpy.CreateVersion_management(editDB, 'DBO.QAQC', 'MICHAEL', 'PUBLIC')
#arcpy.CreateVersion_management(editDB, 'DBO.QAQC', 'KAREN', 'PUBLIC')
#arcpy.CreateVersion_management(editDB, 'DBO.QAQC', 'COLLECTOR', 'PUBLIC')
# /////////////////////////////////// ANALYZE DATASETS AND CALC STATISTICS /////////////////////////////////////
# NOTE: Rebuild indexes can accept a Python list of datasets.
# Get a list of all the datasets the user has access to.
# First, get all the stand alone tables, feature classes and rasters.
dataList = arcpy.ListTables() + arcpy.ListFeatureClasses() + arcpy.ListRasters()
# Next, for feature datasets get all of the datasets and featureclasses
# from the list and add them to the master list.
for dataset in arcpy.ListDatasets("*", "Feature"):
arcpy.env.workspace = os.path.join(workspace, dataset)
dataList += arcpy.ListFeatureClasses() + arcpy.ListDatasets()
# reset the workspace
# Concatenate all datasets into a list
datasetList = [ds for ds in dataList]
print "rebuilding indexes"
# Execute rebuild indexes
# Note: to use the "SYSTEM" option the workspace user must be an administrator.
arcpy.RebuildIndexes_management(workspace, "SYSTEM", datasetList, "ALL")
print('Rebuild Complete')
print "analyzing datasets"
arcpy.AnalyzeDatasets_management(workspace, "SYSTEM", datasetList, "ANALYZE_BASE", "ANALYZE_DELTA", "ANALYZE_ARCHIVE")
print "analysis complete"
#Allow the database to begin accepting connections again
print "Set databases to allow connections..."
arcpy.AcceptConnections(editDB, True)
# \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ If Script Successful, log into database \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
print 'Data has been synched succesfully and logged in the tracking database'
# conn = pyodbc.connect('Trusted_Connection=yes', driver='{SQL Server}', server="ggogisapp1.scwater.com", database= "Database Connections/Arden.Admin.sde, ALL")
# cursor = conn.cursor()
# # You will need to create a table in sql to log to and add fields that you want to log into and pass them as params to this cursor
# cursor.execute("""INSERT INTO [dbo].[PYTHON_SCRIPT_TRACKER] (ScriptName,RunDate,Status,ErrorCode) VALUES ('ReconcilePost_AssetIDs_QAQC',GetDate(),'Success','All Steps Completed Without Error'); """)
# conn.commit()
# del cursor
# conn.close()
# print 'Script is finished'
# /////////////////////////////////Register as Versioned Error handling area////////////////////////////////////////////
except:
failMsg = '\nSCRIPT FAILURE IN VERSIONING PROCESS\n'
print failMsg
conn = pyodbc.connect('Trusted_Connection=yes', driver='{SQL Server}', server=sqlsvrname, database=sqldbname)
#You will need to create a table in sql to log to and add fields that you want to log into and pass them as params to this cursor
cursor.execute("""INSERT INTO [dbo].[PYTHON_SCRIPT_TRACKER] (ScriptName,RunDate,Status,ErrorCode) VALUES ('ReconcilePost_AssetIDs_QAQC',GetDate(),'Failure',(?)); """,failMsg)
conn.commit()
conn.close()
sys.exit()
print "Script has run its course and is now complete"
