Hi everybody,
I try to use Arcpy on Apache 2.4 and CGI that is basic example. But I can't, It always display error message like "Not signed into Portal".
Although I signed in.
And then, I check about Licensing
So, ArcGIS configuration is ok.
Now I show you see what Apache configuration
- httpd.conf, I have enabled LoadModule cgi_module modules/mod_cgi.so
- ViltualHost,
=> I checked, VirtualHost works well without use Arcpy.
Apache Service is running
Python example script
The result
But When I import Arcpy in my Python script, It has the problem.
The bellowing is apache-cgi-example.py content
#!C:/Program Files/ArcGIS/Pro/bin/Python/envs/arcgispro-py3/python.exe
# coding: utf-8
print("Content-type: text/html\n\n")
print("")
print("<h2>ArcGIS runs on Apache 2.4 + CGI</h2>")
import sys, os
import bottle
import cgitb
cgitb.enable()
realpath = os.path.dirname(os.path.realpath(__file__))
sys.path.append(realpath)
print("<p><b>Project path</b>: {}</p>".format(str(realpath)))
app = bottle.default_app()
app.config.load_config("%s\\app.conf" % realpath)
try:
print("<p><b>Output path</b>: {}</p>".format(str(app.config['app.output_path'])))
import arcpy
# Arcpy can overwrite output
# set workspace dir
arcpy.env.workspace = app.config['app.output_path']
# initiation for volume calculation
arcpy.CheckOutExtension("3D")
arcpy.CheckOutExtension("spatial")
except Exception as error:
print("<p><b>Cannot import Arcpy. Error</b>: {}</p>".format(str(error)))
The problem is "Not signed into Portal"
The page content is
Can your please help me?
Thank many help!
Note:
- It has the same problem on IIS environment
- I am using ArcGIS Pro version 1.3 (Python version 3.4.4) 64bit
- I am using Apache 2.4.23 64bit
