Create a geoprocessing tool that allows the generation of geometry based on an expression in Arcade similar to how QGIS has the "Geometry by Expression" tool.
I have a tree dataset with a point feature of the tree stem and a number of integer attributes of crown spread and would like to be able to create a polygon geometry based on creating new points based on these, buffering, convex gull and merge. This is easily done in QGIS using the below but would like ot add the process into a wider tool taking a hosted feature layer collected in S123.
convex_hull(combine(buffer(make_point($x-("Crown_W"/2),$y),"Crown_W"/2),
combine(buffer(make_point($x+("Crown_E"/2),$y),"Crown_E"/2),
combine(buffer(make_point($x,$y+("Crown_N"/2)),"Crown_N"/2),
buffer(make_point($x,$y-("Crown_S"/2)),"Crown_S"/2)))))
This is onbiously only one use case but i can see it being really useful for a number of other applications
