Hi all,
I'm putting together a python script that utilizes spatial joins (arcpy.analysis.SpatialJoin()), and I'm running 4 spatial joins one after the other, each using the previously created layer for the next target layer, 3 of the joins require the use of a distance_field_name, but the final join layer only produces the last distance_field_name.
Is this the expected functionality of the tool? Do I have to create a separate field to move those values into before running the next join?
It's a pretty basic script, but I've attached it here.
# Variables established not shown
# all field mapping required
fieldmappings = arcpy.FieldMappings()
fieldmappings.addTable(san_layer)
fieldmappings.addTable(r"memory\road_buffer")
fieldmappings.addTable(select_building)
fieldmappings.addTable(water_layer)
fieldmappings.addTable(rail_layer)
# fields to keep
keep_field =["COA_ID","DIAMETER","ROADCLASS","FULLNAME","Distance_To_WaterBody","Distance_to_RailRoads","Distance_To_Social_Features","Depth","PROX_TO_REG_SEN_SCORE","DIAMETER_SCORE","ROAD_CLASS_SCORE","SOCIAL_RESOURCES_SCORE","DEPTH_SCORE", "REGULATORY_SCORE","SOCIAL_SCORE","ECONOMIC_SCORE","COF_SCORE","COF_DESCRIPTION","Distance_to_RailRoads","Distance_To_Social_Features","Distance_To_WaterBody"]
for field in fieldmappings.fields:
if field.name not in keep_field:
fieldmappings.removeFieldMap(fieldmappings.findFieldMapIndex(field.name))
# Spatial Join where main and buffer intersect
# Fields required from road layer = ROAD_CLASS, FULLNAME
#Fields required from sanmain = COAID,
arcpy.analysis.SpatialJoin(san_layer, r"memory\road_buffer", r"memory\RoadJoin", "", "", field_mapping = fieldmappings)
arcpy.analysis.SpatialJoin(r"memory\RoadJoin", select_building, r"memory\BuildingJoin", "", "", fieldmappings, "CLOSEST", "500 Meters", "Distance_To_Social_Features")
arcpy.analysis.SpatialJoin(r"memory\BuildingJoin", water_layer, r"memory\WaterJoin", "", "", fieldmappings, "CLOSEST", "100 Meters", "Distance_To_WaterBody")
arcpy.analysis.SpatialJoin(r"memory\WaterJoin", rail_layer, r"memory\FinalJoinLayer", "", "", fieldmappings, "CLOSEST", "10 Meters", "Distance_to_RailRoads")
Everything runs as expected, other than the loss of the distance_field_name field between each spatial join.
Thank you for any help!
Caitlin
