Any API in ArcGIS Pro SDK to set the layer attribute field order. Manually Data Design used or Arcpy also another option. However, I did not see any API in Arcpro SDK. I checked "SetFieldOrderAsync" but it required the active table view. But I plan to implement the order for many layers after adding the features to the map.
Thank you for the advice
