Hello everyone,
I am having a problem with the Splash Widget it does not display. ,And I am thinking that may be the name I imported in the widget "widgets_Splash_Widget_31" is not the same the application is expecting. I just replaced the Spalsh Widget with another one I created with WAB developers with some new text.
Where can I find the Splash id in the WAB Developer that matches "id": "widgets_Splash_Widget_31" in config.json?
How does the "id" gets the name "widgets_Splash_Widget_31"?
Can I use ArcGIS Online Assistant
Config.json
"version": "2.2",
"id": "widgets_Splash_Widget_31",
"name": "Splash",
"config": "configs/Splash/config_Splash.json"
