I have a strange one. Maybe someone has dealt with this in the past.
One of my larger layers (a few hundred thousand points) is causing issues all of a sudden.
- This layer previously had no issues.
- The problems began a couple days ago out of the blue (no layer chances, server updates, new processes, etc.).
- Now, whenever the web app which contains the layer is opened, the layer immediately tops out ArcSOC EXE, and the layer in question doesn't work.
- The layer is set to a dedicated instance pool.
- Currently, it has min 3 max 3 instances. I have played with various configurations as well (0/1, 1/1, 0/2, 1/3, etc.)
- There is a scale view set, so the layer isn't rendering when the web app opens. There are also two copies of the web app atm, built in WAB and EB. Doesn't matter which version is used.
- The layer was republished form ArcPro last night.
- Server has 4 physical and 8 Virtual cores. Resources in general aren't an issue right now for this machine.
Before opening web app:
After opening web app (the layer also doesn't work properly in the web app - it just does this while the web app is open):
Again, everything was fine a few days ago. This is very abnormal behaviour. Typically, using the web apps wouldn't even register on the server.
