hi everyone
I want to add sqlserverExpress Table into arcgispro layout with sdk.net . for this purpose i use below code but when i start editing my feature layer ,it says "this workspace is not editable"
what is my code problem?
DatabaseConnectionProperties connectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
AuthenticationMode = AuthenticationMode.OSA,
Instance = @localhost\sqlexpress,
Database = "db_" + LoginUserControl.userId.Replace("-", "_"),
Version = "dbo.DEFAULT"
await ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
Geodatabase geodatabase = new Geodatabase(connectionProperties);
Map map = MapView.Active.Map;
CIMSqlQueryDataConnection sqldc = new CIMSqlQueryDataConnection()
WorkspaceConnectionString = geodatabase.GetConnectionString(),
GeometryType = GetGeomType(StrGeomType),
OIDFields = "Nid",
Srid = "4326",
SqlQuery = String.Format("select * from [db_{0}].[dbo].[layer_{1}]", LoginUserControl.userId.Replace("-", "_"), layerId),
Dataset = "test",
DatasetType=esriDatasetType.esriDTFeatureClass
var lcp = new LayerCreationParams(sqldc){ Name = layerName, };
FeatureLayer flyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
thanks
