When I need to Draw a Line using this widget; once the Draw and Measure Tool Window is opened:
- I click on the Draw Line Tool
- Then, in order to get the line to draw I need to double left click the mouse in rapid succession inside the map window at the point where you want to draw a line. Then I need to single left click the mouse to start drawing the actual line.
- If I do not do this, then I will simply be grabbing and moving the map with the closed fist mouse cursor; no line will draw.
This only affects the Draw Line Tool, all the other tools in the Enhanced Draw and Measure Widget work like they are supposed too, meaning you do not have to do what I mention here to get them to work.
Any ideas?
