Hi, I have the most of my pull data to work, but what I can't seem to figure out is to search through the table and get the value.
So I need the survey to block for input, if the parcel has already been surveyed, but I'm not storing any parcel geometries in the surveys feature layer.
So my idea was to create an ID field created from the parcel data. I enter a parcel and using pull data to retrieve the ID, that ID is stored in the Surveys feature service.
If a survey is submitter, it will then include the Parcel ID.
If I in a week walk into the same parcel, I will get the same ID from my parcel feature service, but since it's now also stored in the feature of the survey, I can then remind the user to use the inbox and edit, instead of trying adding 2 surveys in the same parcel.
I can't seem to get there though.
Maybe I'm seeing it wrong, maybe there's also another solution or a more standard way of doing this. The goal is to never be able to create a second survey within a parcel, but being forced to edit existing using repeats.
Thanks.
