Hi all,
I'm using a Bad Elf Flex Mini Extreme with RTK corrections from the Massachussetts DOT CORS (MACORS) with Field Maps. When I first open the field map it warns me that the coordinate system of my map (WGS 84) may be incompatible. So I dove under the hood in the Field Maps app to create a new location profile for MACORS. I set GNSS coordinate system to NAD 1983 2011(6318) but I'm stuck where app wants to know the projection and datum transformation.
Thanks!
Paul
Thank You! I received the following from a user in Mass.
Awesome, we are in a different state, but it seems that transformation is the go to for all of the CONUS. Good to know.
This EOS article and story map covers the profile setup in field maps pretty well.
Configuring Location Profiles in ArcGIS® Field Maps for iOS® - Eos (eos-gnss.com)
Configuring the Bad Elf Flex for Use With ArcGIS Field Maps
The datum transformation we are using is "~WGS_1984_(ITRF08)_To_NAD_1983_2011 + WGS_1984_(ITRF00)_To_NAD_1983" USA - CONUS and Alaska; PRVI + USA - CONUS and Alaska; PRVI. I had to call a trimble rep a while back when setting up the profile for our R2. We recently got some Flex Minis and a Flex Extreme unit. We are using them with this same tranformation and they are working very well on the Flex units.
