I'm trying to create an offline map in Field Maps that will allow our crew members to stream their location using a line layer (usually done when hitting the "Start Streaming" pop up on the online map/app. When I tried to make the regular layer they use to do so available offline, it said "The layer requires true curve client editing, which is not supported in Field Maps". Does anyone know a workaround to capture tracks offline on Field Maps?
Thanks!
Mikayla
