I want to add the custom Tiles ,which is created by Arcgis with catalog.
it can get the tile image from server but i can't view in map. my code like this.
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Custom TileLayer <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.12</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> type<SPAN class="operator token">=</SPAN><SPAN class="string token">"text/css"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token">"http://localhost/arcgis_js_v412_api/arcgis_js_api/library/4.12/esri/themes/light/main.css"</SPAN><SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
html<SPAN class="punctuation token">,</SPAN>
body<SPAN class="punctuation token">,</SPAN>
#viewDiv <SPAN class="punctuation token">{</SPAN>
padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN>
height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"http://localhost/arcgis_js_v412_api/arcgis_js_api/library/4.12/init.js"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/Map"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/config"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/request"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/Color"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/Extent"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/geometry/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/support/TileInfo"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/widgets/LayerList"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"esri/layers/BaseTileLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
Map<SPAN class="punctuation token">,</SPAN> esriConfig<SPAN class="punctuation token">,</SPAN> esriRequest<SPAN class="punctuation token">,</SPAN> Color<SPAN class="punctuation token">,</SPAN>Extent<SPAN class="punctuation token">,</SPAN> SpatialReference <SPAN class="punctuation token">,</SPAN>TileInfo<SPAN class="punctuation token">,</SPAN>
MapView<SPAN class="punctuation token">,</SPAN> LayerList<SPAN class="punctuation token">,</SPAN> BaseTileLayer
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// ******************************************************* </SPAN>
<SPAN class="comment token">// Custom tile layer class code </SPAN>
<SPAN class="comment token">// Create a subclass of BaseTileLayer </SPAN>
<SPAN class="keyword token">let</SPAN> spatialReference <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4550</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">let</SPAN> extent<SPAN class="operator token">=</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Extent</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
xmin<SPAN class="punctuation token">:</SPAN><SPAN class="number token">273521.70494464</SPAN><SPAN class="punctuation token">,</SPAN>
ymin<SPAN class="punctuation token">:</SPAN><SPAN class="number token">3302005.502287823</SPAN><SPAN class="punctuation token">,</SPAN>
xmax<SPAN class="punctuation token">:</SPAN><SPAN class="number token">440043.09505535045</SPAN><SPAN class="punctuation token">,</SPAN>
ymax<SPAN class="punctuation token">:</SPAN><SPAN class="number token">3379261.04</SPAN><SPAN class="punctuation token">,</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN>wkid<SPAN class="punctuation token">:</SPAN><SPAN class="number token">4550</SPAN><SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">let</SPAN> tileInfo <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">TileInfo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
dpi<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">96</SPAN><SPAN class="punctuation token">,</SPAN>
rows<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">256</SPAN><SPAN class="punctuation token">,</SPAN>
cols<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">256</SPAN><SPAN class="punctuation token">,</SPAN>
compressionQuality<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
origin<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
x<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">5123200</SPAN><SPAN class="punctuation token">,</SPAN>
y<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10002100</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
lods<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
level<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
levelValue<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
resolution<SPAN class="punctuation token">:</SPAN><SPAN class="number token">264.5838625010584</SPAN><SPAN class="punctuation token">,</SPAN>
scale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1000000</SPAN>
level<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN>
levelValue<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN>
resolution<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">132.2919312505292</SPAN><SPAN class="punctuation token">,</SPAN>
scale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">500000</SPAN>
level<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN>
levelValue<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN>
resolution<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">66.1459656252646</SPAN><SPAN class="punctuation token">,</SPAN>
scale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">250000</SPAN>
level<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN>
levelValue<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN>
resolution<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">33.0729828126323</SPAN><SPAN class="punctuation token">,</SPAN>
scale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">125000</SPAN>
level<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN>
levelValue<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN>
resolution<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">16.933367200067735</SPAN><SPAN class="punctuation token">,</SPAN>
scale<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">64000</SPAN>
<SPAN class="keyword token">var</SPAN> TintLayer <SPAN class="operator token">=</SPAN> BaseTileLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createSubclass</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
properties<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
urlTemplate<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
tint<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
value<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> Color
<SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">,</SPAN>
tileInfo<SPAN class="punctuation token">:</SPAN> tileInfo<SPAN class="punctuation token">,</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> spatialReference
<SPAN class="comment token">// generate the tile url for a given level, row and column </SPAN>
getTileUrl<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>level<SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">"http://192.168.20.244/TileCache/Layers/_alllayers/"</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"L"</SPAN> <SPAN class="operator token">+</SPAN> dojostring<SPAN class="punctuation token">.</SPAN><SPAN class="token function">pad</SPAN><SPAN class="punctuation token">(</SPAN>level<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'0'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"/"</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"R"</SPAN> <SPAN class="operator token">+</SPAN> dojostring<SPAN class="punctuation token">.</SPAN><SPAN class="token function">pad</SPAN><SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">16</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'0'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"/"</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"C"</SPAN> <SPAN class="operator token">+</SPAN> dojostring<SPAN class="punctuation token">.</SPAN><SPAN class="token function">pad</SPAN><SPAN class="punctuation token">(</SPAN>col<SPAN class="punctuation token">.</SPAN><SPAN class="token function">toString</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">16</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'0'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">"."</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"png"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// This method fetches tiles for the specified level and size. </SPAN>
<SPAN class="comment token">// Override this method to process the data returned from the server. </SPAN>
fetchTile<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>level<SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// call getTileUrl() method to construct the URL to tiles </SPAN>
<SPAN class="comment token">// for a given level, row and col provided by the LayerView </SPAN>
<SPAN class="keyword token">var</SPAN> url <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">getTileUrl</SPAN><SPAN class="punctuation token">(</SPAN>level<SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// request for tiles based on the generated url </SPAN>
<SPAN class="comment token">// set allowImageDataAccess to true to allow </SPAN>
<SPAN class="comment token">// cross-domain access to create WebGL textures for 3D. </SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="token function">esriRequest</SPAN><SPAN class="punctuation token">(</SPAN>url<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
responseType<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"image"</SPAN><SPAN class="punctuation token">,</SPAN>
allowImageDataAccess<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// when esri request resolves successfully </SPAN>
<SPAN class="comment token">// get the image from the response </SPAN>
<SPAN class="keyword token">var</SPAN> image <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>data<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> width <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>tileInfo<SPAN class="punctuation token">.</SPAN>size<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> height <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>tileInfo<SPAN class="punctuation token">.</SPAN>size<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// create a canvas with 2D rendering context </SPAN>
<SPAN class="keyword token">var</SPAN> canvas <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">createElement</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"canvas"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> context <SPAN class="operator token">=</SPAN> canvas<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getContext</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"2d"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
canvas<SPAN class="punctuation token">.</SPAN>width <SPAN class="operator token">=</SPAN> width<SPAN class="punctuation token">;</SPAN>
canvas<SPAN class="punctuation token">.</SPAN>height <SPAN class="operator token">=</SPAN> height<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Draw the blended image onto the canvas. </SPAN>
context<SPAN class="punctuation token">.</SPAN><SPAN class="token function">drawImage</SPAN><SPAN class="punctuation token">(</SPAN>image<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> width<SPAN class="punctuation token">,</SPAN> height<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> canvas<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">bind</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Start of JavaScript application </SPAN>
<SPAN class="comment token">// Add stamen url to the list of servers known to support CORS specification. </SPAN>
<SPAN class="keyword token">var</SPAN> stamenTileLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">TintLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
tint<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Color</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#004FBB"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"test"</SPAN>
<SPAN class="comment token">// add the new instance of the custom tile layer the map </SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>stamenTileLayer<SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">// create a new scene view and add the map </SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">360788</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3309983</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
extent<SPAN class="punctuation token">:</SPAN> extent
<SPAN class="comment token">// create a layer list widget </SPAN>
<SPAN class="keyword token">var</SPAN> layerList <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">LayerList</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>layerList<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"top-right"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
My tile url formate:http://192.168.20.244/TileCache/Layers/_alllayers/L00/R00000061/C0000004f.png
what't the problem ,can you help me
