Hi team,
I have installed portal ArcGIS 11.2 in linux aws instance with elastic IP.Internally i am able to access the url .curl -v http://elastic-ip/arcgis/home* Trying *.*.*.*:7080...* Connected to elastic-ip (elastic-ip) port 7080 (#0)> GET /arcgis/home HTTP/1.1> Host: elasticip:7080> User-Agent: curl/7.81.0> Accept: */*>* Mark bundle as not supporting multiuse< HTTP/1.1 302< Location: http://elastic-ip:7080/arcgis/home/< Transfer-Encoding: chunked< Date: Fri, 31 May 2024 09:58:04 GMT< Server:<* Connection #0 to host elastic-ip left intact
But from browser not able to access.getting site can not be reached.
What did you name the web adaptor when you installed it? Internally it will be at /arcgis, but the web adaptor would put it somewhere else based on the name you configured for it, like /portal, /server, etc.
if "site can not be reached", that means the issue is in the network, and your request initiated from the browser hasn't reached the ArcGIS portal yet.
