Hi. I'm exploring the option to use Experience Builder for a project. The app needs to have a map and a list widget, as well as a filter widget and these elements need to be connected. So, for instance, If a filter is applied, it must filter both the map and the list. Likewise, when a user searches, both the map and the list should show the search results. So far I'm not having much luck. The search box in the map widget just works on the map, not the list. Same for the search and filter tool in the list - it does not work on the map.
I'm pretty new to this so maybe missing something. Any advice? Thanks.
