I am calling a geoprocessing service in a web app. The geoprocessing service has one parameter. But I am not sure how to find the parameter in the javascript code to send it to the geoprocessing since I am using an editor widget to first create the polygon and then run the geoprocessing service. Can you guys take a look at my code and tell me how I reference a feature set from the editor widget results? Thank you! var stewardship = new FeatureLayer("http://tfsgis-iisd01:6080/arcgis/rest/services/MyMapService2/FeatureServer/2",{ mode: FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); map.addLayers([ActivityArea,ActivityPoint,stewardship]); function initEditor(evt) { var templateLayers = arrayUtils.map(evt.layers, function(result){ return result.layer; }); var templatePicker = new TemplatePicker({ featureLayers: templateLayers, grouping: true, rows: "auto", columns: 3 }, "templateDiv"); templatePicker.startup(); var layers = arrayUtils.map(evt.layers, function(result) { return { featureLayer: result.layer }; }); var settings = { map: map, templatePicker: templatePicker, layerInfos: layers, toolbarVisible: true, createOptions: { polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ], polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON, Editor.CREATE_TOOL_CIRCLE, Editor.CREATE_TOOL_TRIANGLE, Editor.CREATE_TOOL_RECTANGLE ] }, toolbarOptions: { reshapeVisible: true } }; var params = {settings: settings}; var myEditor = new Editor(params,'editorDiv'); //define snapping options var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CROSS, 15, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0, 0.5]), 5 ), null ); map.enableSnapping({ snapPointSymbol: symbol, tolerance: 20, snapKey: keys.ALT }); myEditor.startup(); } gp = new esri.tasks.Geoprocessor("http://tfsgis-iisd01:6080/arcgis/rest/directories/arcgisoutput/CalcFeaturesStewardshipNoParam4_GPServer/CalcFeaturesStewardshipNoParam4") gp.setOutSpatialReference({wkid:102100}); on(dom.byId("button"),"click", function() { alert("TEST") // gp.submitJob(params, completeCallback , statusCallback,function(error){ // alert(error); }); The Pythonimport os, sys, arcpy arcpy.env.workspace = "Database Connections\\sars.sde\\" value = arcpy.GetParameterAsText(0) Input_Polygons = "Stewardship" Input_Polygons_Layer = "SamplePoints_Layer" arcpy.MakeFeatureLayer_management(Input_Polygons, Input_Polygons_Layer) with arcpy.da.UpdateCursor(Input_Points_Layer, ("City")) as rows: for row in rows: row[0] = value rows.updateRow(row)
