I'm curious about options to improve drawing performance of the subnetworks when the aggregated geometry is saved. As a specific example, a client has a water system with 3 subnetworks in the pressure tier. Using the default template symbology from the solution, draw times in the web map are <2 seconds with all layers turned on excluding the water network/water pressure. Turning on this layer consistently pushes draw times over 30 seconds. This is confirmed in the ArcGIS Server logs that performance is isolated to this layer.
I suspect it is an issue with a complex "spider web" geometry over a wide area that thus lacks a useable spatial index (compared to other features). I suppose a possible workaround is to forgo the water network/water pressure feature and instead symbolize the water lines (mains, services) again based on the pressure subnetwork name. Anyone have suggestions on how to improve the drawing performance of this layer?
Michael Parma
