Hello! I would like to combine symbology but can't seem to figure out how to do so. Let's assume I have a survey with three total questions - A geopoint question to capture location, a select one question with 2 possible answers, and a select one question with 3 possible answers.
The first question determines if a case is open or closed. I currently have open cases appearing as a red dot, and closed cases appearing as a blue dot.
The second question determine who the case is assigned to. Person A appears as a triangle, person B as a square, and person C I would like to be a circle.
What I would like is to add the open/closed status to the shape assignments. So an open case assigned to person B would be a red square. A closed case assigned to person A would be a blue triangle.
Is this possible? When I attempt to make the corresponding selections in the map viewer, the options appear to be mutually exclusive.
Any help would be greatly appreciated!
