Hello, all
I am trying to add WmtsLayer in the operational layers - like it is in the example for WmsLayer (draw attention 't' is absent) : https://developers.arcgis.com/kotlin/sample-code/add-wms-layer/. Layer is added without any run-time errors (at least load result is successful, isVisible is true and so on) but it is invisible on the the map. Network monitoring shows that there is no requests to server for tile getting.
Is it valid/supported WmtsLayer usage scenario?
NOTE:
At the same time this WmtsLayer can be displayed normally as the layer in the Basemap (scenario from arcgis examples: https://github.com/Esri/arcgis-runtime-samples-android/blob/main/java/wmts-layer/src/main/java/com/esri/arcgisruntime/sample/wmtslayer/MainActivity.java). Displaying WmtsLayer in the basemap is not acceptable due to another limitations - mostly due to WmtsLayer transparency issue - it is visible when it is in the the Basemap.baseLayers with index 0, and layer (with really required basemap info) in index 1 is covered by it, and via versa.
SDK: com.esri:arcgis-maps-kotlin:200.3.0
