Hello i have a WPF application that was running with esri version 200.0 and net version 6.0After we upgraded to net version 8 and esri version 200.3 im getting the following exception (after calling ArcGitRuntimeEnviroment.Initialize()):Could not load ArcGis Runtime(RuntimeCoreNet200_3.dll) or one of it dependencies Ensure "Microsoft Visual C++ 2015-2022 Redistributable" is installed with inner exception : Unable to load DLL "RuntimeCoreNet200_3.dll" or one of it dependencies: the specified module could not be found(0x8007007E)And when i checked the AcGisRuntime200.3 folder all i see the resources folder(the .dll file seems to be missing)I have tried the following solutions Solution 1 Solution 2 im using the following nugetsEsri.ArcGISRuntime.Hydography 200.3Esri.ArcGISRuntime.WPF 200.3Esri.ArcGISRuntime 200.3window version 1809(OS build 17763.5458)
First thing to note is we require minimum Windows build 19044 in 200.3 (19041+ SDK).Could you share what you have in your csproj file? Are you overriding runtime identifiers or Platform/PlatformTarget in that project?If you use our project templates and create an ArcGIS WPF project, does that work and how does it differ from your project?
when i use the project template is working finei the only think(?) that is different the ".deps.json" is different, in my project the relevant dlls are missing from there(my project is a class library project)Also in my project i have the following<TargetFramework>net8.0-windows10.0.19041.0</TargetFramework><CopyLocalLockFileAssemblies>true</CopyLocalLockFileAssemblies><SupportedOSPlatformVersion>10.0.19041.0</SupportedOSPlatformVersion><AppendTargetFrameworkToOutputPath>false</AppendTargetFrameworkToOutputPath><AppendRuntimeIndentifierToOutputPath>false</AppendRuntimeIndentifierToOutputPath>when i copied the above to the template project it didnt affected the result(worked fine)
> my project is a class library projectI don't quite understand that then, since you can't run a class library project. I assume there's an app project in the end?
Of course there is an app project at the endalready solved by referencing Esri runtime 200.3 at the main project
