I have a task that I am attempting to determine if it's possible to utilize an Arcade script to accomplish, however I have limited knowledge of Arcade. My scenario below:
I have a Utility Pole layer and a Riser layer, and the Riser layer needs to contain an ID attribute from the Pole layer on which it is snapped. As I create a new Riser feature that is snapped to a pole feature, Is it possible to create a script that will extract the ID attribute from the pole layer and insert that ID into a field in the Riser layer?
Appreciate any any help that could be offered!
