Hi there!
I'm trying to add a WebTileLayer to my map, however the resulting URL when fetching tiles isn't correct.
My code:
const webTileLayerFromUrl = new WebTileLayer({
esriMap.basemap = new Basemap({
baseLayers: [webTileLayerFromUrl],
Example of correct URL for these map tiles (works): https://maps2.wien.gv.at/basemap/geolandbasemap/normal/google3857/19/181789/285965.png
A URL generated by my code when run (does not work): https://maps2.wien.gv.at/basemap/geolandbasemap/normal/google3857/19/288513/154195.png
I'm assuming I've done something wrong when creating my WebTileLayer, but I'm not quite sure how to fix this.
Things I've tried so far:
- Swapping the {x} and {y} in the urlTemplate (wasn't the issue)
- The geolandbasemap uses a tile size of 256. I tried adding a tileInfo with size = [256, 256]. That did not help either.
- Swapped the urlTemplate for another, to make sure there was no issue with my code itself: E.g. https://a.tile.openstreetmap.org/{z}/{x}/{y}.png loads just fine.
If anyone has any advice, I would greatly appreciate it 🙂
