I am trying to utilize the Feature display order option that is found in a layer properties in Map Viewer (see image below). Changing the Order by option has the desired effects; however, after saving the setting and saving the map, the next time I return to the map the Order by returns to 'Default data order'
I first noticed this because the display order was not being honored in Experience Builder which makes sense if it is not being saved. I believe this was working as expected several months ago so not sure if a recent update broke this.
What is the best way to contact ESRI about this bug?
Thank you,
Kevin
