Is it possible to remotely remove a previously downloaded map in Field Maps?
There is a setting in Field Maps Desktop to Hide the Map. Doing this will remove the map from the group's folder, but the map is still accessible in the "On Device" section. We've tried deleting the map area and changing the sharing status to owner only, but the map is still accessible in the On Device section after trying these as well.
Right now, it looks like the only way to remove an already downloaded map is to do it manually, but it'd be nice if there was an option do to it remotely. Does anyone know of a way that this can be done?
Thanks!
