Hello I used webappviewer and therefore it was recommended that I should use experience. I was used to using smart editing and then I could click on an object e.g. flat and then right click to edit any of those properties. Now I don't get the option to edit and it's either you click on the object or you click on edit. Is there a possibility to add the option where you can right click to edit an object? Greeting Ahmed Jama
Hi @AhmedJama , right-clicking is not usually an option on the web. Please could you record the behavior and functionality you are describing and share the recording here so I can better understand the functionality you are looking for?
