I'm using .onDrawStatusChanged to observe when the map is loading and not. While the status is .inProgress, I'm showing a spinner. There are two problems with this approach:
Questions:
Hi Svein, thanks for the question and welcome to Esri Community (for Swift 😉)!
Before we come up with an answer, I'd like to know what are the exact conditions that you want to show a spinner for the map/scene view?
There are many stages for a map/map view to be "loaded" - loading a map from a portal over network; drawing the map view - basemap tiles, features, and more; waiting for the panning animation to stop on a map view; waiting for the viewpoint change animation, etc.
Depending on what you want to show a spinner on, there might or might not be a variable currently available. From there our engineers can provide more thoughts.
I'd like to add that for most cases when you aren't using a huge dataset (with 10k+ features, for example), the "loading" time would be minimal. So depending on the usecase, a spinner might not be a must have.
Thanks!
Thanks for your answer. We are developing a mobile app for use in the forestry industry with relatively large number of layers, and used over relatively slow networks. That is, spotty cellular reception deep inside the forest, far from public infrastructure.
The maps are often available offline, but we do also support online maps, which are often very slow. In fact, we must assume that the maps are very slow, and both loading layer metadata, as well as individual tiles, are error prone.
An entrepreneur is using our app to harvest timber, and need to be relatively sure that the map in front of them is accurate, finished drawing, and up-to-date. A layer may e.g. be showing endangered species' habitats, or culturally significant spots that are illegal to driver over with heavy forestry machinery, due to regulatory reasons. Or property borders, and the entrepreneur cannot harvest timber from a neighboring property, due to legal reasons.
We can use layer state to know if the layer itself is loaded, visible, and without errors or warnings, but we can't use it to tell (as far as I can tell) if the viewport is finished rendering. This can sometimes take several seconds, sometimes part of the requests even time out (in which case drawing is complete, but we'll see warnings, methinks)
Typically the user will pan the map around with their finger, and a spinner is displayed as the map loads tiles and rasters, until finally coming to a rest a some time later, and the spinner goes away.
If we remove the "blue dot", or the user is looking at an area that does not include himself, the `drawStatus` seems to work as expected. Ideally, I think I'd like to have the layer state include some kind of tile loading status.
Here's an example of user interaction.
Notice as the user pans the map, the spinner appears. After about 30 seconds, the map would seem "done", had it not been for the spinner. But there are still about 15 more seconds of loading/drawing afterwards.
These extra seconds of the spinner does nothing to the map, since all tiles that are loading happen to be empty, but the spinner give the user important clues that the map is indeed not done loading yet.
Thank you for the details. This is an issue that we've logged before but haven't revisited for a while. The reason why the location display triggers a draw status change is that, the blue dot itself is rendered as a symbol-graphic, which also goes through the rendering pipeline, so it triggers an update whenever it redraws.
I'll keep you updated as our team discuss the potential fixes in the SDK. Meanwhile, workarounds might be either don't show the location display, or disconnect the data source, while the data is loading. However, they are not ideal fwiw. Ultimately we need to fix it in the SDK.
For now, we've solved this in the network layer, by pipelining map layers through a proxy, and keeping track of incoming, outgoing and cancelled requests. This is not ideal, but it works as long as we only show one map view at a time.
After some discussion here are a few things…
