I noticed a frustrating behavior in raster representation on ArcGIS Pro that seems to want to trim my max/min Raster values.
The same raw raster reads In ArcMap 10.3:
High: 325.4
Low: 193.8
(good)
In ArcGIS Pro:
High: 312.8
Low: 235.9
(bad - missing values)
This affects the visualization. Its terrain data, so if I run the contour tool, it DOES work on the lower values in Pro. Basically the symbolism for the raster is just wrong and trims data of the top and bottom. I have tried to change that in the layer symbology with no success. In ArcMap 10.3 the data is represented more accurately and less "lossy", and I can use the custom histogram correctly to focus down towards minimum values for example. In ArcGIS Pro this appears to be impossible as the statistics are wrong in the symbology tab. Additionally if you go to Layer Properties> Source, it says "Statistics have not been calculated". 10.3 says the same thing as well though.
Can anyone help me change this behavior in ArcGIS Pro? Am I suffering from a bug or a "feature"? I am running ArcGIS Pro 2.2.0.
