Hello all!
We have a goal for subcontractors to create Stormwater asbuilt drawings in CAD using our existing Geodatabase’s Schema. How can I correctly import the existing geodatabase’s schema (XML) to a .DWT? we have symbology for our conveyances and catch basins in arc pro and we would want them to use our feature class symbology in a disconnected workflow.
Thank you!
Hi!
There are a couple of things you can do here. We often see our users needing to work with disconnected subcontractors. The two paths I recommend are as follows.
OR
With both of these, there is an easy way to have them use your symbols. CAD and GIS symbols are just different and there is no easy way to export them out of ArcGIS to be used in AutoCAD. Its also a bit by design as we know most CAD users have blocks they already want to use for symbols. If not you can create AutoCAD blocks that match your GIS symbols to add into the template file but this will be an all manual process.
I hope this helps!
Thank you Randy! I realized I didn't reply to your thorough response. We are looking into both solutions you provided I know we will have further questions.
