I’m new to using Survey123 Connect to build public-facing surveys — looking to understand if there’s functionality where I can add a question that asks the survey taker to “select a point” from a layer on a map and provide an answer that references that point. The map would have pre-existing point data from a hosted layer that I created, the respondent would select one of those points, and provide information about the condition for example. Is this possible? Thank you for your help! https://vlc.onl/
