I have multiple coordinates in one field which represent a geofence or a polygon of influence. How do I plot these points ? XY to Point allows just one. The image below shoes the coordinates represented as lat/long. Is there a way I can automate this or is there a particular tool?
You can create and add geometries to a feature class in Python using an Insert Cursor:
https://pro.arcgis.com/en/pro-app/latest/arcpy/data-access/insertcursor-class.htm
See the last code example, at the bottom of the page, for how to do this for polylines.
See also:
https://www.e-education.psu.edu/geog485/node/323
Or, if you reformat your data a bit, you might use this tool:
https://pro.arcgis.com/en/pro-app/latest/tool-reference/defense/coordinate-table-to-polygon.htm
