Greetings,
I received the error "external component has thrown an exception" when trying to add data to a map from Catalog in Pro. I had added other data just a few minutes before, no problem. But then tried again several times and kept getting the error.
I restarted Pro and my computer, but it didn't help. Restarting Pro was the only solution I had found posted on the Esri community previously, and several people said that that worked. I tried adding the data from the icon in the upper ribbon, instead of catalog and still got the error.
This appears to be a common error across many types of software, but so far I have not found any solution I can translate to Pro.
Would appreciate any insights!
