Hi all,
I have created a 'Miles' field and I want it to update as and when the ShapeLength field is changed. I cant work out a simple way to do this. I have polyline data in a database/SDE and I want to be able to edit existing and create new lines with the miles field updating as the ShapeLength field does. Can anyone help please?
Dave
Hi @davidchamberlain2,
You can do this using Attribute Rules. Execute the Add Attribute Rule tool for your feature class. Ex:
Maybe use the calculate rule: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/calculation-attribute-rules.htm
Thank you both,
I used attribute rules and it works well.
Thank you
