I'm deploying Workflow Manager onto a QA environment and encountering issues. I used some Esri-provided scripts to migrate my Workflow items in a dev environment to a QA environment and apart from a couple of manual updates to things like Job Name format, everything else seemed to copy over just fine.
On the QA environment, whenever a user creates a job through the Workflow Manager Pane in ArcGIS Pro, the Workflow Pane shows the job as Running, but it never gets out of this state. It's supposed to transition to an Open Pro Project Item to open a Map and point the version to the newly created version.
I can correct this by clicking on 'Switch active Workflow Item', the Cloud button in the bottom left of the panel, and re-entering the Workflow Item. It will have shown to properly enter the next step, opens the created version and it runs as normal. However, having to back out of the Workflow item and re-open it for every job isn't ideal for the users, as it should automatically transition to the next step (which is set to run Automatically when entered).
I have not encountered this issue on the dev environment, and verified the Workflow Job Diagrams and settings in WFM are the same.
My Dev environment has ArcGIS Pro 3.1.2 and my QA environment has ArcGIS Pro 3.1.1. Both use WFM 11.1.
Any ideas on where the problem might be?
In searching around, I'm guessing maybe this patch could work but I'm not sure otherwise what the issue could be.
https://support.esri.com/en-us/patches-updates/2023/arcgis-workflow-manager-server-11-1-patch-1
