in Survey123 the bind::esri:style colum can be set for the image capture Method=browse
1. ¿how change or modify the location where the "browse" is pointing? ¿Can it be set to point to a different location or specific folder or has to be in an On-line service?
2. If the Survey123 was created from an existing Feature Layer, and share the same "points layers" with QuickCapture. I wonder ¿if photos taken with QC can be retreived form a Survey123 image question with the method set to "browse"?
