Under the Measure distance tool I would like it to be possible to check the distance perpendicular to a line from a known point or object. Many times I would like to check a distance from a known object such as a building or structure to the existing boundary line of a parcel. I do not believe Arcmap had this option either. There would need to be a perpendicular option under the Snapping options.
@PatrickAllen3 does the current Measure Offset tool not work for you? https://pro.arcgis.com/en/pro-app/latest/help/mapping/navigation/measure.htm#ESRI_SECTION1_BBFB377E7E1143D1AC81FC955ED9771A
My mistake, I was looking for a perpendicular option, it appears to works just fine. Thank you for the help and clarification on the tool.
Glad that works for you!
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
