So i was given a excel. xls table with Lat and Long of decimal degrees minutes and i need to import it into ArcMap. I am needing to convert them to decimal degrees in order to import it into ArcMap. How can i convert this table the entire table to decimal degrees. I tried using the Add XY Data but when i select the file nothing happens, do i also need to convert the table certain format before add it to arcmap? Can this be done through arcmap or field calculator? I would appreciate any help.
The table is populated as following
| Long | Lat |
| -116 37.863 | 43 41.353 |
