I'm creating multiple surveys to inspect different asset types that will contain completely different questions (poles vs transformers for example). In each survey, I want to include a repeat for the user to log follow-up work that needs to be completed after the inspection (site restoration, labeling, etc.). There can be multiple follow-ups for the same inspection. I was hoping to have this repeat tied to the same feature layer in each survey so our administrator only has to look through a single feature layer for outstanding work. Is it possible to accomplish this or will I have to have separate "follow-up" feature layers for each survey then combine them in a map or application after the fact?
Thank You,
