I want to create a CIMSymbol that will be used in a unique value class renderer. The symbol should be a circle with red fill and the letter R in it.
This is what I have but the symbol comes out as empty and the Symbology tab shows "symbol has inconsistent geometry logic"
var textSymbol = SymbolFactory.Instance.ConstructTextSymbol(ColorFactory.Instance.BlackRGB, 8);
var fill = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.RedRGB);
List<CIMSymbolLayer> symbolLayers = new List<CIMSymbolLayer>
new CIMVectorMarker()
MarkerGraphics = new CIMMarkerGraphic[]
new CIMMarkerGraphic()
Symbol = textSymbol,
TextString = "R"
fill
_symbolRightLimit = new CIMPointSymbol() { SymbolLayers = symbolLayers.ToArray() };
_symbolRightLimit.SetSize(10);
I have tried to use the Symbology tab to see what I can fix to make it work but it appears that the only way to make that error go away is to add a global effect to the symbol? And while the error went away, the symbol still did not render.
I have also tried to play with the CIM Viewer to see what I can do but have not managed to find anything.
