Environment
ArcGIS Monitor 2023.2
Windows Server 2019 Standard
RAM 24 GB
PostgreSQL 14
Problem description:
ArcGIS Monitor stopped writing collected metrics into PostgreSQL database and accordingly nothing shows up in monitor web application. After further analysis, we found that ArcGIS Monitor is trying to insert metrics data but the partition tables are missing. For example, monitor is trying to insert metrics data for 12 Sep 2023, unfortunately, monitor does not find metrics_data_2023_09_12 partition table. It keeps trying to insert records till the heap memory is full and it throws heap limit Allocation failed.
After creating the partition table manually, monitor started to write metrics data successfully and it shows up in the Monitor web application. Accordingly, the root cause and the effect is probably that the partition tables are not being created.
