Background:
With CentOS 6 and CentOS 8 now end of life, and CentOS 7 end of life (EOL) set to arrive on June 30, 2024, we are planning to migrate our ArcGIS Enterprise software from CentOS 7 to Rocky Linux 8.
Our ArcGIS Enterprise deployment scenario:
- Our ArcGIS Enterprise software are installed on CentOS 7.9
- We have a base ArcGIS Enterprise deployment with federated ArcGIS server (also hosting server) install in a different VM while portal, Datastore and Web Adaptor installed in another VM.
- We are at ArcGIS Enterprise version 10.8.1
The plan is to migrate the CentOS 7.9 based ArcGIS Enterprise 10.8.1 to a machine running Rocky Linux 8. Once 10.8.1 is running in Rocky Linux 8, we want to Upgrade to 10.9.1 and then 11.1.
Our preferred tool to migrate ArcGIS Enterprise from machine to machine is the “webgisdr utility tool”.
- According to Esri documents “The webgisdr utility records the software versions of the ArcGIS Enterprise components when you create a backup file. The standby deployment to which you import the file must be at the same version as your primary deployment”. In simple words the tool requires both machines to have the same version of ArcGIS Enterprise installed for the migration to succeed. In our case the ArcGIS Enterprise install in CentOS and Rocky Linux must be on the same version (ArcGIS Enterprise 10.8.1).
- According to Esri system requirements document, CentOS is supported only till ArcGIS 10. 9.1 version and Rocky Linux in compatible with ArcGIS Enterprise 11 version only.
- Does this means we cannot install the same ArcGIS Enterprise 10.8.1 version on both machines (CentOS and Rocky Linux) because of the compatibility problem.
- Or can we assume that Rocky Linux 8 is supported for ArcGIS Enterprise 10.8.1 as Red Hat Enterprise Linux Server 8 is listed on the supported OS for ArcGIS Enterprise 10.8.1 and as we know Rocky Linux 8 is 100% binary compatible with Red Hat Enterprise Linux Server 8?
- The General question is how do we approach the inevitable migration of CentOS based Linux machines to other supported Linux distributions in our case to Rocky Linux?
Mehretab
