We have maps that we produce in ArcGIS Pro and a significant part of these can be the location of features containing attachments and also showing the attachments. In the past, this would mean showing the points on a layout (in the map frame) with a number label, then on a separate layout we would manually load each photo (after already downloading them) and applying a text label to refer back to the points with.
IDEA: Create an "Attachment Gallery" element item that dynamically updates based on features visible in your map extent. Any attachments of features in the map extent would be displayed in the gallery element. Settings for the element could include options to influence the attachment size (fitting options such as: minimum/maximum width/height, fill element, stacked, etc.), overflow options, count options (maybe as a separate dynamic text option), arrangement options (i.e. top to bottom - left to right, centre outwards, etc), framing options (add a frame to each photo), overlap tolerances (allowing more photo's into a full space), rotation options (force portrait, force landscape, maintain original, random), attachment format filter (JPEG, PNG, PDF (preview), TIFF, etc)
Being able to link this to a map frame on a separate layout would be even better so you could maximise your map space and your gallery space on 2 different sheets.
