I am running simple code:
from arcpy.sa import Raster
print("Creating delta_t_veg raster...")
d2 = Raster(D2_VEG) # Replace with the actual path to your raster
d1 = Raster(D1_VEG) # Replace with the actual path to your raster
delta_t = d2 - d1
scratch_save_path = f"delta_t_veg_new "
delta_t.save(scratch_save_path)
and it returns an error:
RuntimeError: ERROR 010240: Could not save raster dataset to delta_t_veg_new with output format FGDBR.
When I first save the raster to tif and then trying to upload it to gdb with
arcpy.CopyRaster_management(scratch_save_path, final_save_path)
I get:
arcgisscripting.ExecuteError: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds. General function failure No spatial reference exists. Failed to execute (CopyRaster).
I have double-checked paths, I have tried shorter paths for gdb, the workspace is set to my gdb, and delta_t is legit (I can save it to .tif to disk).
Can someone help? It seems like a path issue, are raster tools sensitive to paths on Windows? When running raster calculator in ArcGIS Desktop it is working. When running above code in notebook, it is not....
